Branson seat replacement help
Ms4720ch
Hello, im in desperate need of advice. Has anyone replaced their tractor seat in a cab model. I have a Branson 2017 4750ch. My current suspension broke and the seat is original. Im 6 ft 3 and 210, brush hog 4 uneven hill fields. My cab area is not spacious and seems like alot of new seats are wider. I was looking at the km 117 pro, yet the seat is 23in and im uncertain if it will be too close to the pto lever and brake. The grammer msg65/531 could be optional. There is a black talon, yet not great suspenion wise.
looking for suspension and comfort under 800.00. My original seat I felt like I was going to slide out of it. Has anyone actually replaced a cab seat and if so, what did you find works or does not work.
Appreciate any help
Appreciate any help
Hello Ms4720ch, welcome to YT! You wouldn’t know this coming in here the first time unless you knew something about forums in general. If you look at thread in the list below your about the Branson 3820 rear axle you will see that it was dated July 2025. Ya, there is not much activity in this sub forum.
By doing a “Google” this came up from Facebook that person recommended a seat bought from Vevor.
Facebook tractor post
That’s about the best I can do for you, good luck!
Seat replacement in a Branson cab is tight. The KM 117 Pro is 23" wide. That's likely too wide for a 4750ch cab. The Grammer MSG65 is narrower and better for height. You're 6'3". Grammer has better suspension and adjustability. Black Talon is cheaper but suspension is weaker. Spend the extra on Grammer. It'll fit and save your back. Measure your current seat width before ordering
Thanks for the response, I did go with the grammer actimo m. It was a perfect fit and im glad i did. Back saver for sure.
