Break-in engine oil
4020guy
What's the theory with break-in oil? I generally use Rotella 10w30 for the first 50 hours and then change to 15w40 Plus 50 Deere. Winter oil of choice is Rotella 0w40.
I O/H a lot of big engines and I put the oil in that the customer is going to run, we keep every thing clean as we go back together and haven't had any problems, I have never used break-in oil ever...
Thanks Tim. Deere even sells it. Just starting to assemble a Deere kit in my 71 4020. The sealing rings started to leak coolant into the crankcase. The engine ran great but with 8K hours.... Got a high performance engine rebuilder guy to mic the crank and it was only 1 thousands' less than spec. So it's getting polished up and standard bearings rolled in. I wish the new kit had the same thrust bearing as the old one but I guess the new one is OK. Not really looking forward to installing those sleeves with the pistons and those big rods all at once. I'll keep you posted.[and getting the oil pump screwed into timing the injector pump]
While I won't disagree with Tim's success I will tell you what was told to me years ago at John Deere parts school when I was a parts manager. Plus 50 oil was just then new. The Plus 50 oil (and other brands of premium oil) do such a good job of lubricating that they sometimes do not allow rings to seat. I have noticed this first hand. Some John Deere break-in oil was used in an engine even after it had been "broken in" with Plus 50. After a change of the BE oil the engine ceased to use oil and ran better. I use the break-in oil in everything now. It's a good product. Mike
I use it as well, and have great success with my major engine jobs. You have to fill it with something the first time, why not use what the factory uses?
I can't disagree with useing it, and I'm sure there is only a minute diference in the formulation. One thing that always ran in my mind was if it helps the rings seat faster, will it help the bearings wear fast also? In the begining it was only supposed to be ran for a short time, what if the customer "forgets" and runs it as a normal oil change period, will that shorten the life of the O/H ? These are the little thoughts that we kicked around in the past, so years ago we started running what the customer used and sent them to the field.
Well, as with anything, you have to "read and follow label directions"...If you're prone to forget things, forgetting regular oil changes probably led to the overhaul in the first place. It's the higher molybdenum levels that help the most.
Break in oil simply does not have as many additives as regular oil. Thus, it allows the rings to wear slightly or seat.
Equally important, after you confirm no oil leaks are present and the cooling system is full after the thermostat opens is to put a load on the engine. Most people slowly increase the load, first drive the tractor aroung 15 min or so, stop and check for leaks, etc. Then pull a loaded wagon, etc, etc. This is just as important as break in oil.
I memory serves me correctly Deere recommends changing the break in oil and filter after 50 hours. I always cut the filter open with a large can opener type tool and inspect for debris. You will see a small amount, that is the purpose of the filter.
Hope this helps.
When we had our 4440 overhual at the deere dealer It came back with a sticker printed by john deere that said this engine had break in oil in and it was to be left in for 100 hours
The break in oil is used to help the ring seating. If you use John Deere break in oil it will be 10w30 break in oil.
When we get our new sprayers every spring, we run break in oil in them at 100 hour intervals until they can go 100 hours without using any appreciable amount of oil which on those takes from 100-300 hours. Tractor engines are easier to break in though assuming that they are worked and not idled around.
