Breaker plate
iowaboy
Any special way/ tricks to install a breaker plate on a 1949 ford 8n front mount 6v positive ground. No conversions on it
(quoted from post at 21:55:37 08/05/11) Any special way/ tricks to install a breaker plate on a 1949 ford 8n front mount 6v positive ground. No conversions on it
an't get much simpler...drop it in, install retainer ring, install timing lock screw, electrical connections...done.
If you're installing a new plate, save the concave head brass screw from the old plate & use that instead of the standard brass machine screw most new plates come with. Make sure you get the plate seated below the groove & that the C clip is positioned correctly, as in the picture.
Do a continuity check before you put it back on the tractor.
Follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem.
50 Tips
