Breathing new life into
SVcummins
wore out big 4wd tractors
Stupidity knows no boundaries.
And farm show magazine publishes some REALLY "way out there" stuff.
On the other hand, I'm sure FUN was had by all involved!
What a waste of HP. Weight distribution is so bad on them that way. Would probably only pull about half what they would normally. The versatile would have been better to just added some to the front frame if needed for the engine to fit in right.
Half a tractor is better than no tractor.
As I recall, both of these tractors not only had engine problems, but front end problems as well. Those 30 series Deere articulateds were famous for front end problems. Both tractors were pretty much scrap metal.
They took fencerow tractors and fencerow trucks, put them together, and made something functional. Not necessarily pretty, FUNCTIONAL.
I'm glad so many of you have the resources to fix every piece of equipment back to factory new condition regardless of cost, but in the real world the numbers just don't pencil out. That's if you can even find decent parts to fix them with...
Wow-What is the old saying-I ain't seen nothing like that before. I bet they both be a dream in the mud-or most likely a nightmare-Thanks---Tee
Exactly . Why not take a wore out piece of junk and
make it into something you can use ? You could
easily put 40 grand in either one to return it back to
factory condition well that doesn?t make sense a lot
of times In production agriculture
