Briggs and Straton engine troubles
herk
Hello a friend of mine was running his Craftsman rider 26 hp B&S engine in the shed and out of no where ( No knocking or anything )it lost valve timing it stopped running with compression leaking out the exhaust, is this a major repair, now it cranks over vary easy with no abnormal sounds just compression out the exhaust, my ?? is he said I could have it ,it is a nice mower but is it fixable or worth it .. Thanks Bryan
Stuck valve is likely the cause. If OHV, removing the rocker and removing the valve spring (Easy with groove joint pliers)the valve can be lubricated with Blaster or?, then rotated a=pushed and pulled till free. I have used a hand cranked hand drill to spin the valve while pushing in and out to get juice in the guide. Then use engine oil on it to make the lube last. Reassemble and there it is. In the bock can be done but requires the head removal. Jim
Do others know if these engines have steel valve seats? Sometimes the valve in block Briggs engines would have a seat come out. Not sure if that happened on an OHV model if it would make the valve hit the piston if the seat was out and holding the valve open.
(quoted from post at 01:36:29 11/26/21) Hello a friend of mine was running his Craftsman rider 26 hp B&S engine in the shed and out of no where ( No knocking or anything )it lost valve timing it stopped running with compression leaking out the exhaust, is this a major repair, now it cranks over vary easy with no abnormal sounds just compression out the exhaust, my ?? is he said I could have it ,it is a nice mower but is it fixable or worth it .. Thanks Bryan
I had a nearly new twin Briggs with similar symptoms. Pulled the valve covers and found that the keeper had fallen out of one of the exhaust valves. It was, quite literally, a ten minute fix to reinstall and never had the issue again in the 5-6 years I had the mower.
A BS engine. Best use of them is with a big washer on the end of the crank tie a rope on. The other end tie it to a boat and throw over will hold fine till you want to come in. Just cut rope.
(quoted from post at 05:36:29 11/26/21) Hello a friend of mine was running his Craftsman rider 26 hp B&S engine in the shed and out of no where ( No knocking or anything )it lost valve timing it stopped running with compression leaking out the exhaust, is this a major repair, now it cranks over vary easy with no abnormal sounds just compression out the exhaust, my ?? is he said I could have it ,it is a nice mower but is it fixable or worth it .. Thanks Bryan
Most likley the timing gear went out, if nothing else is damaged, it's a simple fix.
Sometimes the V-Twin Briggs will have a push rod to bend, the intake push rod is aluminum and if that is the case the exhaust valve push rod is steel and can be used in both places. The valve clearance is only .004 on these and is set with the # 1 piston 1/4 past TDC to get the compression relief correct.
While not terribly common I have personally seen it several times where a screw from the choke or throttle plate has worked loose and ended up stuck holding a valve open.
Only takes a flashlight and a few minutes to check to see if they are still in place.
Been 20 years or more ,but I had intec valve issues with the rockers (nut) loosen up . Push rods were out . So what every body said. I suggest take the valve covers off and inspection of what happened.
Dont remember what to fix it to long ago . Might have use use thread lockers
That problem is more common than people know. I have seen it many
times on Onan units. Most of the time no real damage is done. I would
check thar first. Before you dig into it.
Diagnose first.
Take the valve covers off, then you can check for tight adjustments, stuck valves, bent pushrods, and check the valve timing without going into the bottom end.
I'm thinking some of those had a plastic cam gear. One thing for sure, it didn't jump time without a reason. If it's out of time, something had to break.
I have a rider with a 24hp Briggs engine.
A couple of years ago, it started bending pushrods, giving similar symptoms. I mentioned it on this site and someone said to use Mobil 1 synthetic oil.
I found some steel tubing that was an exact press fit over the pushrods. I put a sleeve of the steel tubing over every pushrod and started using Mobil 1 in it. so far, no more problems. I really can't say how much the Mobil 1 helps.
Stuck valve is my choice also. If the gas is old it will sometimes cause valves to stick. I had that happen on one of my gas tractors, by running it with old gas. It does happen. Stan
A B&S engine is not what it used to be. I bought a new Kubota zero turn with a 24 HP B&S. I would buy another Kubota but it won't have a B&S on it.
Being 26 hp. I am thinking it is a twin cylinder engine.
Remove the valve covers. Crank the engine over and observe their operation.
Something like 3 years ago, Briggs decided to switch their engines to 'laminated' or built-up camshafts. The cam gear and the cam lobes are pressed onto a shaft. I have replaced many of these camshafts in their single cylinder engines and so far have seen two of their twin cylinder engines with a failed camshaft.
The single cylinder engines tend to break the compression release off and then they won't start. The starter can't crank against full engine compression.
On both the twin cylinder engines the cam gear broke apart and the valves were not moving.
(quoted from post at 22:00:08 11/26/21) Being 26 hp. I am thinking it is a twin cylinder engine.
Good info there. I'll keep that in mind.
I second the valve seat coming out. Happened to me on a 16 hp. Pulled the head and there it was, cocked to one side under the valve head. Didn't think it would be worth the price of fixing it.
