Briggs engine oil ?
This engine should hold somewhere around 68 oz. of oil. Use a good quality 30W oil. I use Quaker State in all my engines big or small.
When I am unsure of the exact amount I just add a little at a time and keep checking the dip stick. You should be safe to add 1 1/2 qt then start checking every little bit.
If it's a (newer) OHV engine, Mobil 1 Synthetic is GREAT to help keep the valves from sticking, causing the pushrods to get out of place, and likely destroyed.
Most Briggs engines take 20oz. for a push mower and 48oz for the bigger engines.
Jim
As Bob says, use synthetic.
Briggs is very specific about matching the correct single grade of mineral oil to a specific temperature range, but they recommend multiweight synthetic oil for any load at any temperature. They even sell their own brand of synthetic engine oil
I use mobil 1 in all my small air cooled engines and love the performance and low oil consumption.
Here is a link to the Briggs oil chart.
B & S oil chart
