broken block bolt on jd 60
Green Horn
I have a broken upper block bolt can it be right angle drilled and use an easy out with some luck or do I have to split the tractor it not leaking oil and is not use much. Thank You, Hobby Farmer
Where is your block broken????
They are threaded clear thru so you should be able to drill it right on through. I also had broken bolts like you mentioned but had a little bit sticking out to put a bolt easy out on.
better show us a pict. of it dont us easy outs they just brake and then you are screwed jdm i wont give that advice till you know witch bolt he is refereing to
