broken off pipe on hyd pump
baler 46
Hi
Got a little problem on my farmall h the pipe that comes out of the hydraulics pump on the belly pump broke off below the casting on the belly pump.It does have a loader on it too so there was a reserve tank on top of pipe.But i need to get that piece of pipe that's left on the belly pump out of there to put a new pipe on.I can not see the pipe out of the hole,any one got any tricks on how to get that out of there? Will a internal pipe extractor get it out, do not want to lose that piece of pipe down in there.I"m think i could spot weld a pipe extractor to a socket extion and get it out with that .Think that will work? Any better ideas.
You should be able to remove the broken with an extrator.
I would not worry about welding it to a socket, that is what duct tape is for!
If the broken piece should happen to drop inside the clutch housing it will not interfer with anything there. Most likely it will be stuck on the extrator and will take some effort to remove it from the tool.
