Broken Starter Post
Salmoneye
Yes...The post that the solid band attaches to from the solenoid...Copper/threaded, and snapped clean...
Any replacing this without removing the starter?
If it broke off flush with the bottom NUT, there IS a fix. CAREFULLY remove the nut and replace it with a starter repair stud.
If it broke BELOW the bottom nut the starter will have to come apart to have a new stud soldered in place.
<img src = "http://thexton.com/media/products/thmb_Product_164.jpg">
Scroll down near the bottom of the page.
That slotted head bolt solders to the field wire. Dont twist on it,you will mess up the field wire.Field wire is a flat copper bar.Time for the starter shop.
