Broken steering line on 2000 ind.
linster99
I am dealing with a Ford 2000 Industrial and one of the metal power steering lines is broken by the clutch pedal. I dont see any way to replace the line without replacing the hydraulic cylinder too. Is there a way the line can be patched?
you can't remove the line?
anyway.. to answer your question.. yes.. you can braze a metal line for hyds.. PS.. etc. you can get unions for hyd rated pressure too. your call
to be honest. to braze it.. you will want to remove it and clean it...
