Tall T
Just now I tried to hook up the MF to my 3 pt so as to move it down in front of my shop.
I discover that I can't connect one of my sway bars, so like a typical newbie, I tie the sway bar that won't reach, up with a rubber bungie. but of course when trying to move it downs the slope, the right side of the mower is catching in the tire lugs.
After wrestling with it for a bit, at the bottom of a slope, using a pipe to keep levering it free, I drop it right there.
So I'm thinking . . . maybe I have to use my two check chains instead of the rigid sway bars. But when downloading the photos
I have a new thought:
I always wondered what the second hole was for on the left sway bar end. If I connect the right sway bar first and then use the second hole on the left sway bar . . . maybe that's why that second hole is there. (?)
Edit: Pin base to pin base on the MF is 31.5"
on my carryall only 25.25"
So the extra hole on my sway bar must be for wider pin placement of the attachment. Is that right?
Thanks,
Terry
Left Bar with the extra hole.
Closest I could come to lining up holes in right bar.
Thanks,
Terry
