About a year ago, I rescued a 57 420w from the weeds. Ive spent a fair amount of time getting in relatively mechanically sound...after I had to free up the bottom end. Rebuilt carb, new top end gaskets, radiator repair, all new wiring, functional gauges, etc. Im not at the point of making it pretty, still in the working out the bugs stage.
It starts and runs pretty amazing for its age... about one revolution and shes going. After a number of trips driving around pointlessly to give it some use, I decided it was time to load it up and see what it could do.
I hooked up to my brothers 6 brush hog, and while I know its too much mower for this machine, Im not new to tractors, I figure I can go easy and make it work. And it did, for a little while.
Short version, with no tach, Im spinning the PTO up by ear, which was essentially wide open. And it did great, until I fouled a plug. Ive since been through a number of things trying to keep it running long enough to knock down the rest of my field.
Based on some research, I realized it was really struggling to keep temperature, the cooling system was doing too good a job, and my stat probably wasnt closing. Put in a 180 stat, and now she holds temp nicely. I replaced plugs, after verifying my all new 12V ignition system was blasting really good spark, and I added a second washer on the plug, as recommended by some old timers.
For background, Ive compression tested, and am running 120/120. Todays run was the first time Ive used any oil, and based on the 90+ it was out, an the 180stat, and as long as I ran it, I dont feel bad about cooking a little oil on this old girl.
So anyways, I ran it today, and tried something different... I ran it at about 3/4 throttle, which by ear sounded a little slow for the hog, but other then having to ride the first stage of the clutch pretty frequently to keep it from getting into the governor too long and fouling a plug, it got the job most of the way done. I did eventually foul a plug trying to escape a ground wasp nest I got into.
The question finally... is my experience normal for a 420? I expect a 4 hog would probably not be require me to avoid letting the governor do its job, but Im questioning if thats just expected with this old girl. She sounds so good when loaded down and making some horsepower, I just never guessed that it would foul plugs in that scenario. And to be clear, its always the radiator side plug Im fouling. Im running about 1 turn out on the load adjuster.
Would love some criticism / insight here. Thanks in advance.
