Bucket weak
Keel74
I have an old JD 1020 diesel with a closed hydraulic system. It has a 37 loader on it and it had been hesitating while raising. The fluid is full. I use it to lift the tounge on my camper and move the camper. However, recently it wouldn’t raise and was having difficulty raising with nothing in it. The cylinders on it are one way cylinders. I had them rebuilt and they work great but it still won’t lift the tounge on the camper, it just squats the tractor. Doesn’t make any sounds just won’t lift it like it used to and it would lift it with ease before. Is there anywhere I can adjust the pressure?
Come on man, positive feedback only please don’t criticize. The cylinders wouldn’t raise part of the time and as soon as I shut it off they would drop to the ground so I know they were bysssing fluid.
How many hrs since hyd oil suction screen was checked/cleaned. I suggest to check stand-by pressure which should be 2250-2350 psi. Stand-by pressure can be raised by turning screw under bottom of pump in while monitoring hyd gauge.
No the cylinders are not bypassing fluid! If they were you would have leaks from the rod end of the cylinders.
Your control valve is leaking back to the reservoir allowing the bucket to lower!
The OEM one way cylinders on a JD 37 loader are displacement cylinders. As oil is forced into the barrel the rod is pushed out lifting the arms. There is no piston with packing on the rod of that type of cylinder. It can't bypass internally. There either has to be an external leak (hose, fitting, or gland packing) showing or the control valve is worn and not holding.
Slow raising maybe the screen. Not holding is likely in the valve unless there is visible oil running out of it.
Screen was good too but that was a couple years ago. I’m going to drain the fluid and see what it looks like now. Thanks.
Yes, the guy told me there was no piston in there to bypass but something about the seals and o-ring. All I know is before, they would drop right after I shut off the tractor. And now they hold firm. I cleaned the suction screen about 70 hours ago. I tried to attach a video but it was too big.
Squat is not a measureable force.
Hydraulic pressure is. Sounds like hydraulic pressure is not as high as it was previously.
Thats what I thought. I haven’t touched anything else. Do you know the process for increasing the hydration pressure?
Do you have a gauge to check the pressure as Tx Jim suggested? It is best to know what you have before thinking of adjusting. JMHO
I am wondering if the spool of your control valve is moving and centering properly.
