Buda Forklift Distributor
Vicinalvictor
The gear on this distributor shaft needs to be replaced, any ideas or places I may be able to find either a different distributor or replacement gear? Any help is much appreciated as I need to get this forklift running. Thank you.
1000002513-jpg.96866
Like Jim says, above, it's much easier to search for the distributor if you have the engine specifics, like make, model number and age. Otherwise you are just searching by the distributor number, and other numbers may fit your application. steve
Once upon a time Napa had a separate catalog for accessories and all sorts of items not found in other catalogs. My missing copy has a section for distributor drive gears. You could ask Napa.
