Larryb2020
Im giving my son an 8n so he can draw firewood out at his new house this winter. I would like to convert it to 12 volts this weekend. I had a couple questions.
Will GM Delco Alternators work spinning in either direction?
I had a boat once that was diesel and it had a oil pressure activated switch which would power up the #1 Exciter Feild Tap on the alternator once the engine was running and disconnect power once the engine was shut off. Does anyone out there know the NAPA part number for this switch?
I liked the simplicity of this arrangement.
If I don"t use a oil pressure activated switch then I guess I need to use some sort of diode between the ignition switch to prevent battery draw down. Does anyone have a napa part number for this diode? Also is polarity marked on it?
Lastly I have a box of misc ignition coils. I would like to use a 12v with internal resistor so I can just run the ignition wire directly to the coil without an external resistor. Is there any way I can use my ohm meter to test these old coils to determine which ones are 6v and 12 v and internally resisted? Thanks in advance for everyone"s help.
