Buffing out G-1000
NR5STAR
I bought a 1967 G-1000 a few months back. The paint is good but faded, some rust spots on the hood and fenders. We have 3M two part rubbing compound at work that we used on a Floater. Will that work on the tractor or will the rust spots scratch the paint? Thanks Jeff
If you have rust spots chances are it's spreading outwards under the paint and could get bigger and do more damage. In the long run it may be easier to refinish now rather than trying to buff out the appearance.
If you are going to do it, wet sand the finish with 2000 grit sandpaper where you have the surface smooth. It will also remove some surface dirt that might be present. Then you can buff the finish with an auto polisher and make it shiny as glass.
