Bug stopped a John Deere tractor!
ASEguy
Location
Festus MO
My older farmer friend asked me to look at his JD 5420 because it lacked power. He said he barely made it back to the shed before it died. I found it kept sucking the fuel filter dry. Fuel line prior to the filter was badly cracked for a 5+/- year old tractor. I replaced the line , but eventually found a bug stuck in the fuel shut-off valve. I found it by blowing compressed air into the shut-off valve backwards.
I think the fuel tank fill cap should not be by the 3-point hitch area where there is so much debris. Gerard
My brother had same problem on an CIH 684 and it was a ladybug that was in the outlet of fuel tank. I believe ladybug had somehow crawled into fuel filler hose from the Diesel fuel storage tank.
JimB
TOWING BANNERS BEHIND PIPER SUPER CUBS, CO. PLANE TOOK OFF, SPLUTTERING, STAGGERED BACK 2 LAND. JUNE BUG IN UPDRAFT CARB VENTURI...WHEN U CHECK CARB HEAT, OPENS TO UNFILT AIR. BE BLESSED & B THANKFUL. NIK 21 NICHOLS & SHEPARD 25-85 STEAM TR, 4 SALE
You would not believe the number of bugs in my crankcase when I took the tractor apart. Big horseflys, houseflys, all soaked, entombed in oil. A bunch were stuck to the pickup screen.
Aaron
Had the same problem with an Oliver 1550 years ago - would stall out any time a significant load was put on it. Found a spider in the fuel line to the sediment bowl.
I have had it happen before, years ago with an old IH gas burner combine.
It would run great for a while, then die. No fuel coming out, blew air thru the lines into the tank. Would run again for anywhere from a few minutes to several hours.
Finally ended up pulling pulling the sediment bowl assembly out of the tank, expecting rust flakes plugging it.
I saw what looked like a little twig blocking the outlet, pulled it out with a needlenose plier. It was a wasp. DOUG
I just pulled a moth out of the fuel tank of my Farmall Super C. Took over an hour of diagnostics before I thought to look in the fuel tank. Moth would block fuel and motor would die. Once suction stopped fuel would flow and it would start and run for awhile. I still can't tell you how he got in there. Probably from the fuel nozzle at the pump I guess.
I have found that a lot of spiders and other little critters like to hide in the fuel nozzles at my fuel tanks. I have to shoot a little out before fueling up or they go into the tank. Something to look for.
I had a simular problem today, but it wasn't an insect. I was using the WD45 and loader today, and after leaving the tractor shed, it died. I figured it was still too cold, and pulled the choke and it started right up. By the time I put it in gear, and released the clutch to take off , it died again. I went and got a hsndfull of wrenchs, and removed the gas line at the carb, and had just a trickle flow. I chased it backwards to the tank, and ended up removing the sediment bowl unit, from the tank. I found a white cigarette filter in the sediment bowl inlet from the tank, and it looked smaller in diameter than original, like someone had rolled it between their fingers to make it smaller, and then placed it in the aluminum passage of the bowl. It had to of been in one of my gas cans, and been poured in there by me, but no members of our family smokes! SPOOKS MAYBE?
Years ago my 1550 Oliver diesel would run fine in the field till the tank was 1/2 full. Drove me huts for a couple months, let it sit for a few minutes and it starts right back up. One day while racking hay it did it twice and I had had enough! Drained the fuel out got a flash light and looked in the tank and found the problem, It was one of the paperboard gaskets out of a gas can lid!!! After an hour of searching for my flexible claw and an hour of trying, I finally got it out. She has run fine ever since then. Amazing what you find in fuel tanks. Bandit
Back in the days when I sprayed corn with 24-D the little instruction book that's taped to the side of a 24-D jug fell down in the sprayer tank and kept randomly stopping the outlet. Replaced the pump and suction hose before I found the real problem. Lots of lost time! Jim
Weirdest thing I ever found was a 3/4 inch combination wrench in a tractor purchased several years earlier.
Happens pretty often here. The lady bugs are really attracted to the diesel. On a lot of the compact JD's they get stuck in the narrowest point in the fuel line where it makes a turn. Then they make it through and cover the filter.
Have no idea how they get in, perhaps through the bulk fuel tanks.
