building a Farmall H engine
Matt896
I am planning on building a Farmall H puller this winter and have heard that you can remove the sleeves and run 3 9/16" pistons from a Super H over bore kit. Anyone have experience doing this?
Yes you can do that, just need spacer rings for the top sleeve ridge. With the pistons and little head work you can get over 40hp fairly easy.
Andrew
I am planning on building rebuilding my engine the same way glad you posted up what size pistons to use. Where can you get these spacer rings from for top sleeve ridge?
