A 6 volt flash light bulb from an auto store is all you need.
If you need the holder these are available from NAPA. If you need the PN let me know and I will look in my files.
Jeff
thanks jeff .
Got that squared away.
Was able to repair my old socket.
Still fighting the generator.
Had it repaired and still not getting getting a charge,.
Will read more on polarizing.
Manual says to do it before you even hook up the wires to it.
Didn't see that note until now.
Will check the site.
Depends on whether your tractor is 6 volt or 12 volt. 12 volt is 12v x 2.2 watt / 6 volts requires a 2.5 volt x 0.5 watt . The 6 volt type takes a different bulb due to having a resistance winding on the body of the light, this drops the voltage..John(UK)[email protected]
