burr mill - hammer mill ?
swindave
sorry for a stupid question,
but what is the differance between a burr mill and a hammer mill?
there both feed grinders?
never been around one, thanks for you help?
Well the Burr Mill has two cast iron plates with points casted in them,Their usually 6,8, or 10inch that i have seen, the grain gets funneled in between them,while their turning,not quite as much dust as a hammer mill,But i would say the flour for whole wheat bread looks like to me it been threw a Burr Mill,Like for Millet and other hard seeds, it does a good job, but slower, and doesn't heat the flour up as much as a Hammer mill. The Hammer mill doesn't have any mercy on any thing that goes in the chute,and gets reground until it falls threw the screen!
(quoted from post at 06:24:52 11/21/20) The Hammer mill doesn't have any mercy on any thing that goes in the chute,and gets reground until it falls threw the screen!
Yes, the hammer mill will really destroy anything that goes through. Many years ago I remember a nice little 9/16 combination wrench went through our old Case while doing oat chop. The wrench came out in the chop in smoking hot little pieces of metal that we had to shut down and sift out of the chop.
Biggest difference I've seen is that hammer mills generally have a fan/blower to carry the feed away. Burr mills or "choppers" as we call them here, just grind and drop the chop so somebody has the job of shoveling it away all the time. I've actually never used one of that style but have about three of them. Also a hammer mill can have optional size screens to chop fine or coarse. Big holes for hay, small holes for grain.
I used a Letz burr mill on the farm to grind ear corn for cattle feed.. The mill has two burr plates, one stationary and one turns.. Can adjust together to grind fine or course.. For cattle I would set to grind up cobs and just crack the corn kernels.. Hammer mills, as a John Deere or Montgomery Ward uses swinging steel bars to beat grain and material through a screen that can have different hole sizes.. Screen with small holes, grinds fine and screen with large holes grinds course... There could be as many as ten different screens with different hole sizes........
(quoted from post at 08:23:16 11/21/20) Screen with small holes, grinds fine and screen with large holes grinds course... There could be as many as ten different screens with different hole sizes........
For years my dad and I used to change screens when going from grain to hay. In later years I found that the oats were broken up enough just by going through the big hole hay screen so I never changed again. Just as well because the grain screen was worn so thin it was almost worn out. I do the same on this replacement IH mill. It has a screen with big square holes for hay and straw. I use it for oats and they are just fine. No need to grind them up into flour for cattle feed.
Someone mentioned a Montgomery Ward hammer mill a little further down the thread. I don't know who made them for Wards, but we had one when I was growing up. It was a great mill. We had several screens for it but only used the 1", 3/4" & sometimes the 1/2". The screens were easy to change,the "blower & dust collector" worked great, but the thing we liked best was the feed table. It had a "chopper" head that was fed by about a 12 or 14 inch wide belt that was about three feet long. It was controlled by a speed clutch. If the mill's speed slowed, the table stopped & as the mill's speed increased, the table moved forward. You could never plug the mill using the feed table. (I know, because I tried many times.) It worked great for alfalfa hay and ear corn. It sat by a 1,500 bushel ear corn crib that was emptied every year, for many years, through that MW mill. I know, because I dumped thousands of shovels full of ear corn onto that feed table. I don't remember that it ever broke down. I think we did turn the hammers once.
A hammer mill has a flywheel with hammers bolted to it. It runs at a little over 3000 RPMs. Anything that gets in the way of that mass of whirling hammers gets ground up real quick. The material flies through a screen. Material that is too big to go through the screen stays in there and gets beat around u til it is small enough to go through the screen. This all happens in a fraction of a second. This is also why a hammer mill creates more dust and needs a dust collector to separate the dust from the exhausting air. A true simple hammer mill will have a separate fan that sucks the ground material out from under the screen and blows it into a cyclone or dust collector where the material drops out a chute and into a wagon or bags. A more elaborate hammer mill has an auger that augers the feed away from under the screen. So there is less dust involved. I have never used a bur mill but I would think a bur mill would be better for grinding ear corn into cattle feed. Cattle dont like fine powder in their feed.
I have a small burr mill with a 1/4hp motor that's been in my family for many years. We ran shelled corn thru it to grind our own corn meal, as i still do. I have refined the process to end up with a very good meal that makes cornbread taste like corn, not the box. Takes a bit of work, but well worth the effort. I have friends waiting for me to grind every year.
We used to put whole ears of corn through the hammer mill for cattle feed. I assume you just put the grain only through the burr mill
we call them a grain crusher here. i made lots of chop for the cows and pigs. used to load up the 1/2 ton with barley with a shovel! and then set up the crusher with the w6 and a 100 ft. endless belt. was the same belt we used on the thrashing machine. i now have a bunch of 100 ft endless belts. just buy them on auction sales. did this in my school years like when i was 14-18. dad not home and working n the lumber camps and i had to make the chop for cows and pigs. i still have the crusher here and i did use it about 30 years ago to make some chop for chickens. it is an Eatons crusher. you adjust the burrs for course or fine and there is also a lever to adjust how fast for the grain to go trough.
