Bush Hog repair
jbflying
I ran over a stump yesterday and the blades on the bush hog now turn very slowly. The PTO is turning full speed. Is there a break away pin or did I tear it up good? Where should I start first in attempting a repair?
Thanks,
JB
Need a lot more info to be able to help you. What brand is the brush hog?? Most have a shear pin on them so as to help save the gear box. Shear pin most of the time is some place on the PTO drive
Hobby farm
Remove sheilding from gearbox area, and inspect PTO shaft for any evidence of a shear pin which connects the shaft to the stub shaft going in the gearbox.
You can use a grade 2 bolt to act as a shear pin.
