True unless the cutting is easy, and blades are sharp. Jim32 hp. I believe you would be happier with a 5 footer.
I agree.32 hp. I believe you would be happier with a 5 footer.
The cutting would be a heavy cut every once in a while but mostly maintenance.Like other guys have said, a 5 foot cutter would probably be better suited for your tractor. As far as a brand, Bush Hog, Rhino and Woods (just to name a few) are some good quality brands, but have a higher price tag than others. Unless you are wanting a high end brand name cutter or have very extreme conditions you are mowing where you would need a heavy duty cutter, some of the lesser expensive brands are good too. Especially if you are mostly doing regular maintenance mowing.
The bush hog that my grandpa bought with the tractor in 72' was a 6 footer which is why i was thinking that, but as you said a 5 foot might be wise32 hp. I believe you would be happier with a 5 footer.
You got to always make sure the blades are sharpThe cutting would be a heavy cut every once in a while but mostly maintenance.
oh yes i definitely willYou got to always make sure the blades are sharp
mine has weight on the front with the loader attacher so that helpsIf you are in a position to get a six footer, do it. I have one on my 434… front end was a little light , but that was all. A Bush Hog 276 is pretty heavy. Like you say, mostly maintenance, not like you need 100% of the horsepower all the time.
The best feature is that you will be able to mow right up against a wall or fence.
I would look for a 6' and if the cutting gets too heavy, just take a 5' swat. With the loader on the front with wts. , a light front end should not be a problem. Also, I don't hook up the top link unless I need to load it on a trailer. Letting the mower float over the ground works best for me.mine has weight on the front with the loader attacher so that helps
That's what stump jumpers are for.I’ve had a Land Pride 7’ on a 48 HP tractor for 25 years. I’m sold on Land Pride because of theor outstanding gear boxes. Some of the things I’ve hit clearing areas, should have destroyed the direct drive gear box. Including hitting a rock so hard it broke 1 of the blades.
You think stump jumpers will save you from a rock?That's what stump jumpers are for.
In a word YES !You think stump jumpers will save you from a rock?
