bushing replacement
bobby h.
working on my 450c resealing cylinders and hose replacement and see the pin bushing on the bucket boom are worn. are the any tricks or special tools needed. Asking for a Friend🤣🤣
Pretty straight forward to change bushings. Few weld beads around the inside of the old bushings can shrink them some so they come out easier. keep the new bushings in a freezer or packed in dry ice until you actually go to install each one, helps them go in easier. Hollow ram port-a-power head, puller rod, and a plate to go under the bushing can pull them in without a bunch of pounding. Normal bushing replacement things.
