Ultradog MN
Location
Twin Cities
I was hauling a tractor home Saturday - about 100 miles. 20 miles from home I looked in my rear view mirror and saw smoke coming from my front left trailer tire.
Tire was flat and the wheel had an odd angle to it - tipped in at the top.
The axle had broken. Not all the way through but fubar just the same. I called my pal Kenny who came with his trailer and we off loaded the tractor onto his. I limped home empty on 3 tires.
So tonight I ran it down to the big machine shop where he works and we did a jerry rig on the axle. We cut the end of the axle off the rest of the way then found a heavy piece of tubing to splice it back together. Had to turn the OD of the tubing down a bit on the lathe so we could drive it into the axle.
Drilled a few holes for plug welds. Then he welded the original axle back together - Without penetrating into the splice tube. I shot some Buff paint on the tin of his tractor while he welded.
I remembered to bring the camera this time.
Just a 7000 lb trailer. I sure wish I could afford a heavier one. One with 8 hole wheels instead of these 5 hole..
The pine boughs on the trailer are going to the brush pile at deer camp tomorrow.
A good time was had by all.
<img src="http://i61.photobucket.com/albums/h56/Ultradog/100_00601.jpg">
<img src="http://i61.photobucket.com/albums/h56/Ultradog/100_00661.jpg">
<img src="http://i61.photobucket.com/albums/h56/Ultradog/Ken/100_00651.jpg">
You edit your post and lose your pictures??
nice job, very interesting, thanks! Thanks for the offer of power stearing, but it is ok the way it is for my needs, I do apreciate it though , larry
Looks like the axle has been in the process of breaking for some time. It didn't just give out all at once. You got lucky this time. Good to have a good friend to call in that situation. Glad you got it fixed and no one got hurt.
Nice paint.
Nice welding work Kenny!
Jerry, Paint looks real nice to! Oh, remember where we were a year ago?! That certain "white" item came in handy again.... ;-)
