This what you had in mind?
1939-1941 9N Ford Tractor
Year Model Beginning Serial Number Ending Serial Number Engine Distributor Transmission Hydraulics PTO HP - PTO HP - Drawbar Unique Characteristics
1939 9N *9N000001* *9N010233* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 The first 9Ns produced had cast aluminum hood, transmission cover and grill. Many of these are lost now, due to the fragility of this material.
1940 9N *9N010234* *9N045975* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 By 1940 (I don't know if anyone is quite sure just when, in 1939) Ford had changed the rear tire size from 8" x 32" to 10" x 28
1941 9N *9N045976* *9N088887* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 The 9N (and the subsequent 2N) both used a larger rear (approximately 18") and front (approximately 8") axle hub than the later 8N
1942 9N *9N088888* *9N099002* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 Harry Ferguson developed the 3-point lift system that was utilized in the Ford N tractors. Harry had first introduced this lifting system in a "failed" David Brown
1942-1947 2N Ford Tractor
1942 2N *9N099003* *9N105374* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 By 1942 the US was deeply embroiled in WWII and to comply with wartime materials restrictions some changes were made to the tractors, resulting in a model designation change, from 9N to 2N
1943 2N *9N105375* *9N126537* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 Some of the changes that were implemented in 1942 (and had mostly disappeared by 1943) were magneto ignition and steel wheels.
1944 2N *9N126538* *9N169981* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 All 9N and 2N tractors were originally painted grey. The original color was a solid, "battleship" grey.
1945 2N *9N169982* *9N198730* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 Certain components of the tractor were painted black, i.e. the generator and starter.
1946 2N *9N198731* *9N258503* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 There were also certain plated items. The steering wheel nut was plated, as were the rear rims.
1947 2N *9N258504* *9N296131* 123ci 4-cylinder flathead Front 3 speed manual PTO driven 540RPM Transmission 23.07 12.80 In 1947 the Ford Motor Company lost a lawsuit levied by Harry Ferguson and was forced to implement some changes to the 3-point lifting system to prevent further patent infringements.
1948-1952 8N Ford Tractor
1947 8N *8N000001* *8N037907* 123ci 4-cylinder flathead Front 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 These changes culminated in a new Ford tractor model, the 8N. Ford also changed the paint scheme with the model change, to the now familiar "Red Belly" design.
1948 8N *8N037908* *8N141369* 123ci 4-cylinder flathead Front 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 The 8N had a new 4-speed transmission and the new gearing implemented in this transmission increased the available horsepower of the tractor
1949 8N *8N141370* *8N216988* 123ci 4-cylinder flathead Front 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 The 'semi-adjustable' steering box consisted of 2 sector gears that could be reversed to remove "slop" from the steering. The 8N also incorporated a new front and rear axle hub… a much smaller diameter that is noticabley different from the 9N/2N hubs.
1949 8N *8N216989* *8N245363* 123ci 4-cylinder flathead Front 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 In 1949 Ford revamped the steering box on the 8Ns, going to a fully adjustable design. This still wasn't power steering, but did allow for better longevity of the steering system.
1950 8N *8N245364* *8N263843* 123ci 4-cylinder flathead Front 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 All Ford N tractors, from 1939 - 1952 are 4-cylinder with a firing order of 1-2-4-3, CCW rotation. Up until 'now' the distributor was on the front of the tractor.
1950 8N *8N263844* *8N363592* 123ci 4-cylinder flathead Side 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 Mid year 1950 Ford moved the distributor to the side of the engine… where it uses a distributor cap that is more "common" to later vehicles. At this point the generator was moved to the left-hand side of the tractor and a proofmeter was added to record hours worked as well as engine RPM with a rudimentary scale to ground speed and PTO RPMs.
1951 8N *8N363593* *8N433577* 123ci 4-cylinder flathead Side 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 Prior to "mid-year" 1951, all N tractor serial numbers were preceded and succeded with an asterisk (*) which indicated hardened steel sleeves.
1951 8N ^8N433578^ ^8N442034^ 123ci 4-cylinder flathead Side 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 In 1951 the serial numbers were changed to precede and succede with a diamond (represented here by ^) which indicated cast iron sleeves. Cast iron sleeves are .098" thicker than hardened steel sleeves. Many N tractors have been retrofitted with cast iron sleeves during an engine rebuild, however the serial number symbol is rarely modified.
1952 8N ^8N442035^ ^8N524076^ 123ci 4-cylinder flathead Side 4 speed manual PTO driven 540RPM Transmission 27.32 20.80 1952 was the final production year for the 8N and the tractor remained relatively unchanged through the end of its production. The only change that I'm aware of occurred 'sometime' mid-year 1952… reverse was slowed down. This is evidenced by a slight 'hump' in the transmission casing, next to your left heel, seated on the tractor.
1953-1954 Ford NAA Tractor
1952 Golden Jubilee ^NAA00001^ ^NAA02379^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 25.00 The first NAA tractors were built in calendar year 1952, for model year 1953. This has caused some "contention" with Ford tractor enthusiasts as some owners of NAAs built in 1952 like to tout having a 1952 Golden Jubilee.
1953 Golden Jubilee ^NAA02380^ ^NAA77474^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 25.00 1953 was the 50th (Golden) anniversary of Ford Motor Company. And to commemorate the occasion the model 1953 (NAA) Ford tractor was dubbed the "Golden Jubilee". Although there were still many similarities (as well as interchangeable) parts with the 8N, the most evident visible difference between the 2 tractors was the hood. The NAA featured the 'cyclops' circular badge on the front of the hood, with the distinctive "hump" down the center line.
1954 NAA ^NAA77475^ ^NAA_____^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 25.00 There were no functional differences in the NAA between model years 1953 and 1954. The functional differences between the NAA and its predecessor, the 8N, included an overhead valve engine (with a larger displacement, for more horsepower) and an engine driven hydraulic pump which removed the requirement to have the PTO turning to enable use of the 3-point lifting system
1955-1957 Ford 600/800 (and 700/900) Tractors
1954 620 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 31.00 28.00 Beginning in 1954 (for model year 1955) Ford, for the first time in their history, offered multiple, simultaneous, tractor lines. The 600 series featured the 134ci engine that the NAA used and offered 5 specific models
1954 630 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 31.00 28.00 The Ford 630 featured hydraulics and a 3-point lift with an optional 540RPM PTO. It also featured the same 4-speed transmission as the NAA.
1954 640 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00 The Ford 640 was (arguably) the most popular model in the 600 series. It was almost identical to its predecessor, the NAA.
1954 650 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 34.00 28.00 For model year 1955 Ford also introduced the 5-speed transmission,with it's unique shifting pattern. Model 650 featured a single, 10" clutch, providing transmission PTO
1954 660 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 34.00 28.00 Model 660 utilized the same 134ci engine and 5-speed transmission as model 650, but featured a 2-stage, 9" clutch, providing the first factory installed live PTO that Ford offered.
1954 740 ^000001^ ^010614^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00 The 700 series tractors featured the same 134ci engine as the 600 series, only in a row-crop configuration with standard tricycle (and optional wide) front-end configuration.
1954 820 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 45.00 39.00 Beginning in 1954 (for model year 1955) Ford, for the first time in their history, offered a larger (172ci) engine, generating ~45hp. Ford offered 4 specific models in the 800 series
1954 840 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00 Model 840 featured the now familiar 4-speed transmission with the more powerful 172ci engine
1954 850 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00 Model 850 was essentially the same tractor as model 650, only with the 172ci engine
1954 860 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00 All Ford tractors from (model year) 1955 - 1962 were easily distinguished by the 3 part model number. The first digit (8 in this instance) was the series and indicated the 172ci engine.
1954 940 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00 The 900 series tractors featured the same 172ci engine as the 800 series, only in a row-crop configuration with standard tricycle (and optional wide) front-end configuration
1954 950 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00 The second digit in the model number (5 in this instance) indicated the specific model. A 5 indicated a 5-speed transmission with a single-stage clutch (transmission PTO)
1954 960 ^000001^ ^010614^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00 A 6 in the second place of the model number indicates a 5-speed transmission with a 2-stage clutch, providing Live PTO
1955 620 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 31.00 28.00 A 2 in the second place of the model number indicates the 4-speed transmission with NO hydraulics or 3-point lift and an optional (transmission) PTO.
1955 630 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 31.00 28.00 A 3 in the second place of the model number indicates the 4-speed transmission with hydraulics and a 3-point lift and an optional (transmission) PTO.
1955 640 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00 A 4 in the second place of the model number indicates the 4-speed transmission with hydraulics and a 3-point lift and a transmission PTO.
1955 650 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 34.00 28.00 All of the "hundred series" Ford tractors share a serial number pool. So, realistically, serial number 1 could be a 640, number 2 an 850, number 3 a 740, etc. There was no delineation of serial number to model number.
1955 660 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 34.00 28.00
1955 740 ^010615^ ^077270^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00 I have been unable to find any information on any models other than the 740 (and later 741) available in the 700 series tractors.
1955 820 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 45.00 39.00
1955 840 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1955 850 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1955 860 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1955 940 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1955 950 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1955 960 ^010615^ ^077270^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1956 620 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 31.00 28.00
1956 630 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 31.00 28.00
1956 640 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00
1956 650 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 34.00 28.00
1956 660 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 34.00 28.00
1956 740 ^077271^ ^116367^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00 If a 750/751 and/or 760/761 were to exist, they would have power similarities to the 650/651 and 660/661.
1956 820 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 45.00 39.00
1956 840 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1956 850 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1956 860 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1956 940 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1956 950 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1956 960 ^077271^ ^116367^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1957 620 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 31.00 28.00
1957 630 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 31.00 28.00
1957 640 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00
1957 650 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 34.00 28.00
1957 660 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 34.00 28.00
1957 740 ^116368^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 31.00 28.00
1957 820 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 45.00 39.00
1957 840 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1957 850 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1957 860 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1957 940 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 45.00 39.00
1957 950 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 45.00 39.00
1957 960 ^116368^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 45.00 39.00
1958-1962 Ford 601/801 (and 501/701/901) Tractors
1957 541 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00 Possibly in response to the successes of the Farmall Cub and A, Ford released an offset (cultivating) configuration. This became the 501 series. The 541 is the only model that I'm aware of in the series
1957 621 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00 Model year 1958 began the xx1 series of tractors. Some new models (and the 501 series) were introduced.
1957 631 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00 Ford gave a series name to their tractors, beginning in 1958. All 501/601/701 tractor became Workmasters and were painted red. Red cast iron and a red hood, with white fenders
1957 641 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00 All 6x1, 741, 8x1 and 9x1 tractors maintained the same features as their 6x0, 740, 8x0 and 9x0 predecessors
1957 651 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1957 661 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1957 741 ^1001^ ^11976^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1957 821 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00 All 801 and 901 tractors were named Powermasters and maintained a similar painting scheme as the 8N, NAA and "hundred" series before them.
1957 841 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1957 851 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1957 861 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1957 941 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1957 951 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1957 961 ^1001^ ^11976^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1958 541 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00 Beginning in 1958 Ford offered its more "common" tractors with a diesel engine. The Ford diesel engine produced less horsepower, but more torque.
1958 621 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00 On the tractors equipped with the optional diesel engine Ford dropped the name "Workmaster" or "Powermaster" and named it a "Ford x01 Diesel"
1958 631 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00 At some point, by model year 1958 Ford began to offer power steering as an option on their tractors. There was no model designation to indicate the presence of power steering.
1958 641 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1958 651 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1958 661 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1958 741 ^11977^ ^58311^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1958 821 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00
1958 841 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1958 851 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1958 861 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1958 941 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1958 951 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1958 961 ^11977^ ^58311^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1959 541 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1959 611 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 27.00 34.00 In model year 1959 Ford introduced the 'Select-O-Speed' (SOS) transmission. The earlier iterations of this transmission were fraught with problems, but the issues were quickly addressed and the SOS transmission became a solid "automatic" transmission.
1959 621 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00
1959 631 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00
1959 641 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1959 651 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1959 661 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1959 671 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 27.00 34.00 Model x71 tractors were equipped with the SOS transmission but had a single speed (540RPM) independent PTO.
1959 681 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 27.00 34.00 Model x81 tractors were equipped with the SOS transmission with a dual speed (540/1000RPM) independent PTO
1959 741 ^58312^ ^105942^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1959 811 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 37.00 46.00 Model x11 tractors were introduced as an SOS version of the x2x tractor, with no hydraulics (or 3-point lift) and an optional independent PTO
1959 821 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00
1959 831 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 44.00 41.00
1959 841 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1959 851 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1959 861 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1959 871 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00 To showcase their new SOS transmission, Ford required each tractor dealer to order a 'demonstrator' tractor, which was painted gold. The exact model of tractor was at the indivdual dealers' discretion, so there were various models released… with the 871 being (arguably) the more prominent example.
1959 881 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1959 941 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1959 951 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1959 961 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1959 971 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1959 981 ^58312^ ^105942^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1960 541 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1960 611 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 27.00 34.00
1960 621 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00
1960 631 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00
1960 641 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1960 651 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1960 661 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1960 671 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 27.00 34.00
1960 681 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 27.00 34.00
1960 741 ^105943^ ^131426^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1960 811 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 37.00 46.00
1960 821 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00
1960 831 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 44.00 41.00
1960 841 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1960 851 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1960 861 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1960 871 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1960 881 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1960 941 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1960 951 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1960 961 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1960 971 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1960 981 ^105943^ ^131426^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1961 541 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1961 611 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 27.00 34.00
1961 621 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00
1961 631 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00
1961 641 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1961 651 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1961 661 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1961 671 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 27.00 34.00
1961 681 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 27.00 34.00
1961 741 ^131427^ ^155530^ 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1961 811 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 37.00 46.00
1961 821 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00
1961 831 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 44.00 41.00
1961 841 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1961 851 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1961 861 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1961 871 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1961 881 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1961 941 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1961 951 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1961 961 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1961 971 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1961 981 ^131427^ ^155530^ 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1962 541 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00 In late 1962 Ford decided that blue was "the color of quality" and changed the paint scheme of their tractors.
1962 611 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 27.00 34.00 Of course, by this time, the "hundred series" tractors had run their course and the new "thousand series" (2000, 3000, 4000, 5000 and 6000) tractors were being built.
1962 621 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 33.00 29.00 In an attempt to boost sales, many remaining "hundred series" tractors that remained on the dealers' lots were repainted with the new blue and white color scheme.
1962 631 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 33.00 29.00
1962 641 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1962 651 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 35.00 29.00
1962 661 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 35.00 29.00
1962 671 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 27.00 34.00
1962 681 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 27.00 34.00
1962 741 ^155531^ ^______^ (?) 134ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 33.00 29.00
1962 811 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 10 speed SOS None Optional 540RPM Independent 37.00 46.00
1962 821 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual None Optional 540RPM Transmission 44.00 41.00
1962 831 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual Engine driven Optional 540RPM Transmission 44.00 41.00
1962 841 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1962 851 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1962 861 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1962 871 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1962 881 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
1962 941 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 4 speed manual Engine driven 540RPM Transmission 44.00 41.00
1962 951 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Transmission 48.00 41.00
1962 961 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 5 speed manual Engine driven 540RPM Live (2-stage clutch) 48.00 41.00
1962 971 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540RPM Independent 37.00 46.00
1962 981 ^155531^ ^______^ (?) 172ci 4-cylinder OHV Side 10 speed SOS Engine driven 540/1000RPM Independent 37.00 46.00
