Buying a Lime / compost Spreader
With the price of fertilizer for the coming year, I'm really considering applying composted chicken litter. The only problem I'm seeing is trying to get it applied. I had the same issue trying to get lime applied last spring. The custom applicators are all booked out 1-1.5 years or didn't want to mess with 20 acres. One co-op 30 miles away does have a rental spreader but it is too big for me to run. I haven't seen any used lime spreaders for sale locally, only rusted out Willmars... New spreaders go from $7,500 for 3pt models up to $20,000 for basic 5 ton spreaders. I just found an amish deal with 3ton spreaders for around $13,000(link).
Would it be crazy to buy a spreader for 40 acres of my own hay and some custom jobs? I could probably fill a niche spreading for small guys. I figure I can also omit the purchase of a manure spreader by composting my manure down and spreading it with the same spreader.
LINK
I wanted to broadcast fertilizer on several small hayfields. Borrowed a 3pt unit from my son's neighbor, 70 miles away. Worked ok for me. Tried to buy one at TSC right after they y sold out. They issued me a rain check
Still waiting from April. Expired, and they had to reinstate it. Donno if they going to get in some next spring. None of the surrounding stores are in stock either.
Check these guys too. Lead times seem to run over 90 days for about everything, so don't wait too long before ordering. Look at their reconditioned stuff to.
Untitled URL Link
As long as the compost has a consistent texture, like poultry compost, they work fine. However, compost that has large wet lumps, or long, fibrous material that didn't fully decompose, like rye straw, in it, they can be troublesome. For what the going rate 'here' per acre to drive over fields to spread lime, 400 acres of use would pay for that spreader.
I spread mine with a five ton unit that I used to rent for a day for $65.00 from a nearby farmer. He passed on a few years ago and a friend bought it who now rents it out. It could make a good business for you.
farmallboy, where are you located at? i have one, needs some work, free for the hauling. heres a couple pics
i cant remember, id have to look. its at the other farm in the crib . been prolly 20 years since it was used last, have a 14 t baler there too looking for a home.
Glennster, I'm out in Ohio but have family about an hour from you in Onarga. Does that spreader spread lime and compost? It looks like a dry fertilizer only spreader.
For the compost an old manure spreader would work as cheap and easy as it would be. For the lime you could also use a manure spreader just not fill it up, or risk chain problems let alone others from weight. It probably would not spread lime so well but would apply it fairly even if you watch your laps and skips. Otherwise you might have to go the long dollar route. Regular fertilizer spreaders will not spread lime very well since it will not slide down the sides and the dooor is not big enough in the back probably. Big difference between tons and pounds per acre. The manure spreader would probably work better if you can get it and spread during dry time of the year like in late July to end of August. Less water in it so would be a looser product then.
