C/CA transmission swap
andyin ct
Before I jump into this project - I have a transmission from a CA - any issues/surprises swapping it into a C ? Just unbolt axles and transmission and put new transmission in and re-bolt the axles? Thanks
All holes and shafts are interchangeable. The only differences were stated below which has nothing to do with the drive parts. I thought it was already clear. (four bolts at the torque tube and four bolts each side for the final drives, cotter key at the drive shaft) the rest unbolts and bolts back up as you took it apart. You can still use the C drawbar as the transmission width at the final drives are the same. No changes to the brake system for the same reason.
