Scott Todd
Got a C where the engine has enough power to propel the tractor or run the mower deck but not both. I had it hauled to a repair shop but it seemed to work OK for them, and when they hauled it back it seemed to work OK for a day or two, but after sitting several days and attempting to use it again the problem was back. I lose nearly 200 RPM just engaging the mower deck.
I seem to remember an earlier thread about spark advance weights getting sticky but don't know how to get at them. Seems like the vibration and bumping around of being transported might have temporarily shaken them loose. Does that sound like a possibility? This is a pre-war C that's been modified to a coil type ignition system, but I doubt they used an AC distributor. Someone recognized the points as being IH brand when I replaced them a year ago so it wouldn't surprise me if that's also the brand of the distributor.
One other question- the engine tops out around 1400 RPM under no load and I think the manual said it's good to 1600. I've got the throttle rod set as far forward as it can go and manually moving the arm on the side of the carburetor I can get the needed extra speed. I just can't find any other adjustments to give me that extra 200 RPM for actual field work. Where would it/they be?
Scott Todd
Scott Todd
