C or D Case lower radiator tank
RustyCase
Hello. I am in need of a lower radiator tank for my 1938 model C Case. I have already acquired a new core and gaskets. My old lower tank is split and doesnt look salvageable. If somebody would happen to have the hand brake lever I would be interested in that as well.
Thank You
Don K
Good Luck, Those lower tanks are getting hard to find. The lower radiator tank and the block behind the carb are the first things to go from hard water. It would not be difficult to make the entire tank from steel.
(quoted from post at 20:20:06 08/29/23) Good Luck, Those lower tanks are getting hard to find. The lower radiator tank and the block behind the carb are the first things to go from hard water. It would not be difficult to make the entire tank from steel.
Let me check with my friends widow. He had 6 dc 3 tractors that have good lower tanks. Where do you hang your hat at the end of the day? CM
