C seat mount/pivot
SDE
I removed the seat support arm. Someone had removed the original bushing at the pivot point and put two nuts in its place and then put the 1/2 bolt back in. The nuts are now wore out. The bore is 1.00 in the center and 1.125 at the sides.
Was the original bushing a rubber coated steel bushing? Are these bushings made of steel or some other material?
Thank you Steve
This came info out of the parts book for a "C". Hope it helps.
22 2 361140R1 BUSHING, RUBBER BUSHING, seat support pivot rod, 5/8" I.D. x 1" O.D., 1-3/16" long
Those rubber bushings and the steel pin they sit on are available new. I see them on fleabay quite often too.
Steve, The other fellas who replied are correct. The bushings are available from CaseIH, They are a rubber bushing that is tapered. When installing,I put some soapy water n the outside of the bushing as they are a very tight fit.
Thank you everyone. I did not know what it needed because it was obviously not stock anymore.
SDE
