MattMalcome1
I have an old C113 engine off a baler from the 50's I think. There was antifreeze in the oil, but the engine was not run with it in there. I bought it thinking it was parts for a newer (404) international, but it is much older. As far as I know, it could easily be used for parts at the very least. What tractors will this fit? I know the block is different at the bell housing area due to a notch for the starter, but the rest should swap. It has already been fixed (did a nearly invisible job) due to a freezing block, and dosen't leak there. I have no use for in presently, but maybe a tractor could come along??? Any advice or info would be appreciated. (not a Farmall expert). Thanks.
