C310 gov spring 20% over
mfro75
Wondering is anyone could help me out ... have a C301 in a
460 and I?m wanting to get 20% over stock rpms what is the
easiest way and could anyone explain the process for
adjusting all the linkage? I have stock linkage for the throttle
stock 806 spring and gov. it has throttle rod to gov the linkage
back to 715 combine carb.... it?s not stock engine but I?m
guessing that doesn?t matter? I put a bolt inside spring and
could get plenty of rpms but to many I need a way to fine tune
it to 20% over stock 460 rpms...
Can't you adjust your long rod. You will have to make a set screw adjuster somewhere. Or just use vice grips.
