CA cuts out when hot
willyroad
I put a new coil on the CA and that fixed the problem for a while now it is back to cutting off when hot. It will restart but will cut right back off. Ideas anyone?
Take the gas line off at the carburetor and blow air back into the gas tank with the gas cap off and see if it helps.
First off is it 6 volts or 12 volts??? Lack of info can make it harder for us to help you help your self.
First thing to do when it does that is check the spark and make sure you have a good blue/white spark that jumps a 1/4 inch gap.
Next pull the carb drain plug and make sure you have a good steady flow of gas for a few minutes. Catch the gas to look for dirt/water/rust etc.
Take the hood off and run to see if it helps,I had a D10 that would not run right in hot weather once it ran for about 30 minutes.Apparently the ethanol in the gas was boiling in the tank and causing vapor lock.Also move the gas line away from the engine and go to the outside of the air cleaner with it will help to cool the gas.
Check all wiring, my old D14 did that,
Mice had built a nest behind one of the side panels, they had chewed the covering off one ignition wire. As I was driving along, tractor moving over the plowed ground, this bare spot on the wire would swing against the steering column. Temporary cutting off the motor.
I am not that great of a trouble shooter, so it took me a while to find the problem.
I was about to tear into the carb, fuel tank, lines, wiring harness, etc.
Cleaned out the nest, wrapped the bare spot on the wire with electrical tape, problem solved.
Hope yours is as easy, but I felt like a fool after finding the problem.
Those little bastards can cause lots of problems.
My mowing B does that, but it is because it has an unvented gas cap. I just loosen the cap and it starts running fine again. Guess I should find the correct gas cap, but it hasn't been a priority.
David from jax
