Cable Operated Loader Valve
Kerwin
I'm in the process of putting a cab on an Oliver 1650 that will have a 1610 loader with a dedicated control valve. I've got room under the cab floor on the right side to
mount the valve and control remotely via cable and joystick. I'm wondering if anyone has a tractor with a cable-operated remote loader valve and could provide some
photos?
Looking for some examples from something with an aftermarket cab like I will be using (mine's a Hiniker) and not something set up from the factory. I've got a 2-spool
Gresen valve to use for the loader hydraulics. Thanks.
hope this helps a little
as far as i know, many hydraulic spool valves can be converted to cable operation.
or in the case of dump trucks at work, a nut is sometimes welded onto the standard spool valve lever, and the a clevis is threaded onto a remote cable and pinned thru the welded nut to make the connection
cable operated spool valve
or places actually sell kits with cables already attached to the hydraulics.
pretty sure i was told about some small IHI and Hitachi excavators having cables from the joysticks to spool valves under or beside the cab.
