Calling HCooke & Tim Daley
(quoted from post at 13:13:08 02/16/22) I need your email address. Place a magnet near the back of the meter. The needle should move.
Needle moves on my old meter, but meter stays at about negative 15. Magnet moves it only further negative, then goes back to -15.
Email is in my first post above, is on the bottom of all my entries on modern view, & is [email protected].
Thanks again!
Sorry, I did not look at modern view. Email with pictures sent. I have not tested this meter on a tractor. Needle moves with magnet. If you are
interested I will se if I can't test it more thoroughly,
(quoted from post at 10:24:46 02/16/22)
Thanks again!
sing a small magnet (3/16" dia) in handle of a pocket screwdriver, if I approach loop from top, needle moves one way and then if approached from bottom, it moves the other way. Always returns to center with magnet removed.
Thanks JMOR. Using a magnet just like you describe the needle doesn't move at all. It only moves if I use a much larger magnet. Guess that answers that question! Thanks again!
(quoted from post at 10:43:38 02/17/22)
Still have not received an email. Has my computer turned against me? Maybe it's become a JD fan???
ust a WAG here, but that address is unusual to these eyes & might be to others. [email protected]. What is that character between @ and com? the | not I, not1 and not l ??
Thanks for all the help on this thread, but the search is over! I found one just a few miles from me & he only wanted $10 for it if I took it off! I wish he would have had more!!
Thanks guys for offering one!
