calling super99
glennster
chris, did you ever find parts for your bins? i tried to find the post but its ufo or i'm a little on the slow side. anyhoo i was poking around various treasure
piles at the farm......swmo says its junk....throw it out!,, i found a couple gearboxes and such, anything here you can use! i can only post two pics at
a time, bear with me
So far I haven't needed anything, I took the chain off and turned things over. The auger going inside the bin turns smooth. The gearbox turns smooth. The upright auger is a little loose on the bottom, can't get to the top without tearing the head off of the auger. They have taken 2 semi loads out without any issues so far. That being said, I would be interested in the head section in the first set of pictures, it's 6" isn't it? If the upright auger gives me too many problems, I would do away with it and let them put an auger under it to empty bin out. If your cleaning up and getting rid of stuff, I would be interested in that and the pair of Oliver wheel weights the other parts are setting on. I'm about due for a ROAD TRIP!!! Email is open.
i ll set you up with the whole shebang. i wondered why those weights didnt fit anything i had, they are ollies! when this virus thing lifts, we will have to meet half way some where for lunch and transfer the bits and pieces. i ll shoot you an email too
For posting more than two pics just do it as you are but after you hit the post button and the preview shows up you then hit the "return to form" button and you can add two more. Just keep doing that til your done.
chris how far are you from princeton or lasalle peru? iirc, you are kinda west near the mighty mississippi river. maybe pick a halfway point somewhere abouts there for a top secret tractor guy lunch get together when they lift this virus thing. maybe some of the other tractor guys in the area would show for a mini roundup rodeo. kruser can lift the weights over to your truck.!!
Probably a hour and a half. I could do Princeton or Sterling /Rock Falls, LaSalle is just a little further. I could do which ever one you want to. Our daughter lives in Walnut which is between Sterling and Princeton so we are used to that drive. Ya, we would need to have Kruser there to move the weights, heck, I might even buy his lunch for moving them!!!
Got a set of those oliver weights in the back of wifes truck for winter weight. Man are they heavy. A couple years ago I was able to lift them from the ground to the tailgate. No more. It took the ole H and its dual loader to lift them from one to the other. Reminds me I think I should take them out now. Think the snow of any amount around here is done. Hope you use them till nothing is left. lol
