cam bearings for a Case 810B
Gary Steele
The Physical size is 2.250 od
2.120 ID
4 bearings
My 1992 Michigan 77 book says a cam set SH-308S would be the correct set for the size of cam that is in the block
I have worked with parts houses accumalating all the liners pistons valves etc for a complete rebuid but the book keeps coming up with cam bearings that won,t fit.
cam shaft dia.- 2.122
thanks to all gary [email protected]
Gary,
The early case engines had smaller dia cams,
there are no more bearing sets to be had. I have
the cure for your problem on the shelf as I have
the same problem with the J series continental
engines.
I'll send you an email thru yt .
george
