Can someone help me identify this ford loader ?
gobigred94
Trying to figure out if this loader will fit my naa ford.
I agree.. ford 730 loader used on 2000,3000,3400, 3500 and fits the newer x600s and x610 series.. Can be used on the prior series as well.. The Early 3000 (all purpose model) had a smaller pivot pin on the front axle that would wear out eventually as this was later changed to a larger pivot pin to help carry heavier loads. Where the 3400/3500 were built for heavier front end loads. Powered by a front pump with spline pump and shaft to the coupler spiders. There is a long shaft and a short shaft pending on which tractor you install in on.
