Front mount 8N
Just can't get my 8N running right. It does no have enough power to cut the grass on a flat surface. I can get more power if I pull the choke out about an inch but it still is not right. When I start it up, it is stronger and gets weaker as it warms up. I have been messing with this on and off for a year and a half. It used to run perfectly
Compression
From cylinder 1 t0 4
Cold dry test 90, 90, 89 80
Hot dry test 90, 90, 90, 90
Hot wet test (dropped oil in the hole) 100, 110, 100, 100
Electrical
I had this problem as a 6 volt system. new plugs, new wires, 2 coils, new condensor cap and rotor. New Bluestreak points. new carb. Didn't change a thing.
I had a problem that I could never get the 6volt generator working so I figured, great time to convert to 12volt.
All new wiring, another set of plugs and wires. Another carb. New alternator and 12 battery. 2 new 12volt coils I fried one).
I also replaced the plate and bearings that the points sit on.
Key switch - I have bypassed the switch by directly connecting the wires to eliminate switch. No different
New oem resistor
Still the same.
Firing order, counter clockwise at front of tractor 1,2,4,3
PLUGS
AUTOLITE 437. It looks like it is burning just right to me. I've pulled pictures up. Definitely NOT rich. Everything is dry. Has dark color on bottom threads of plug. So I think it is right but could be leaning to the lean side
Pulled all plugs and they look the same
Spark - I have an adjustable spark tester that I have set at 1/8inch. All 4 plugs show a nice white spark.
I've changed the timing up and down. Have it in the middle.
FUEL:
I pulled the fuel line off at the carb and the fuel flows. The fuel filter on the carb is clean as it was on ALL 3 carbs that I have had on the 8N.
Summary: It runs about 60% power. Slight Up hill with mower running cutting grass, it can not make it. As I pull the choke out about an inch, the rpms pick up and it is about 75% power and can cut the grass but not strong. With the choke pulled out an inch, the arm on the carb that the choke is attached to is around the 1 o'clock position. This is where he 8N is happiest which means it is almost at the full choke position when it runs best.
NEXT
Since it runs better at a 90% choked position, that means that it wants less air. My thought now is that there is a problem with the intake/exhaust manifold. Either there is a crack or the gasket is bad. AGREE? or any other thoughts?
Thanks for reading.
Compression
Electrical
New oem resistor
Still the same.
PLUGS
FUEL:
NEXT
Thanks for reading.
