1953 Jubilee NAA
I am finishing up cleaning and adjusting my 3 point lift. I decided to replace the pin that wears against the cam as the arms move up and down. It is about 1/3 worn. I tried the usual trick with the socket over the pin and supporting the socket so the arm doesn't bend but it is really in there. I tried heat with no luck.
I removed the four bolts that hold the adjustment handle, hoping to figure out how to get this out to work on it easier.
I can provide pictures if needed. Any help is appreciated. Do you how to get the adjustment handle off?
BigDawg
WI
BigDawg
WI
