cap/rotoe points/ condenser
bones774
I want to order up tune up parts, i have all the NAPA numbers, but i usually use one of the other auto discounters near my house. How can i figure out what part numbers they will use. Thankls
In my area I have 2 auto parts stores. 1 is O'Reilly's which I use a lot and they can look up the parts just by knowing what tractor you have. I have not replace a condenser in over a decade because now days you stand a 50/50 chance the new condenser will be bad right out of the box.
The other auto parts tore we have in ton is auto zone which is run by a bunch or clueless clowns so I buy nothing there since last time I went in for something they did not even know what I was asking for.
I also only buy KGK spark plugs any more because the champs and auto lite plug do not hold up as well as the NGKs do
I use NGK in all my cars and bikes, was gonna stick with the Champ D21 just because i'm new to tractors, but if NGK works i'll use them. Know p/n offhand? Thansks
Not sure if your Ferguson uses the same plug a the Ford do but good chance it does and if so I use the NGK3112. If it has auto lite 437 or Champ H10 or 12 the NGK3112 is correct
don't think autolite 437's will work in your ferguson. I use autolite 386. if I am wrong hopefully someone will correct me.
My old tractors and small engines run just fine using Champion spark plugs. So does my Model A Ford. Don't know the last time I had to replace spark plugs in anything.
If your tractor is running fine why change anything? I hate changing parts just for the sake of changing them.
I agree with you on that. I have an Oliver S88 that I have had for 10 plus years and have not changed a plug let alone the points and it starts so fast you cannot get your hand off the starter button fast enough 99% of the time
Maybe I need NGK plugs for my Case. I put new AC Delco plugs in it last year. It still spits and spuders till it warms up and then it runs fine. Before the AC plugs I had Champions. The tractor ran good till last year.
Maybe they would help. I have a WD45 that would foul the plugs out with champs or auto lite but has not fouled the NGKs I put in. Did not get 2 months out of the champs or auto lite but the NGK have been in for over year with no problems
i do truly believe engines may be as fussy about plugs as guns are with ammo. i run autolite 386's in my Fergusons and they seem to run fine with them but then again they ran fine with champions too.
