Caption this...
I'd say somebody bought the 2010 Deere that my brother had. I tore that down to overhaul it for him and found the same thing.
My caption would have to be; "Yup, had one just like it". Nearly 50 years ago I bought a 1960 Corvette in need of restoration. It had the base 283 with the wrong (Quadrajet) carburetor on it with an adapter to the manifold. When I removed the carb there was a screw lying on the adapter just about to fall in the manifold (from the carb base plate). I caught it in time and went "whew, that was close". What I didn't do was notice that 2 screws were missing from the bottom of the carb. When I started the engine with the correct carburetor on it the #8 piston got trashed. Live and learn.
When I worked for a Dealer, we served a fleet of trucks. If one would come in with a noise in the engine, we would run it out the road HARD. If we came back quietly, we knew that the screw had imbedded itself in the piston, Good To Go. If it was still noisy , well, it needed torn down anyway!
Back in years putting wheels under 4 kids (so wife and I had something to drive when we needed to go someplace) I went through several GM V8s with the plastic/aluminum cam gear, which at about 80k miles the nylon tips would break off and the chain would jump a few links and guess what............ When I would go to the junk yard and get a newer working replacement, while it was still on the lift, off with the cam chain and gears and on with steel and bronze. Never had another problem......rumor was that the nylon tips were designed to reduce noise.............really???????
(quoted from post at 08:55:25 04/14/19) "Where else was I supposed to put the spare parts?"
Kinda what I was thinking......customers just don't understand when you hand em a bolt or 2 with the bill and the keys......
Rick
NEW 1961 BUGEYE SPRITE...TOLD SALESMAN, NO OIL PRESS..HE SAYS, WE'LL FIX THAT @ 1000 MILE SERVICE..DROVE 80 MI, DID BURGER DRIVIN 10 TIMES W/GIRLFRIEND...NEARLY HOME, TILL IT KNOCKEDD...NO OIL...DEALER OFFERED OTHER STAGE 5, FROM HOUSTON...BUT, IT WUZ RED...GIRLFRIWEND LIKED IRIS BLUE...OVERSEAS MOTORS, FT. WORTH, REBUILT IT...
HEADED TO SEBRING 12 HOUR RACE, FROM TX...CROSSED THAT LONG BRIDGETO PANAMA CITY FL, KNOCKING...HAD LOCK WASHERS, IMBEDDED IN #1 & #2 PISTONS...WHY DID I MAKE THAT DECISION????ENG # 9CUH40178, FROM OREDERING SO MUCH PARTS...BE BLESSED, GRATEFUL, PREPARED....DID U KNOW, ENGLISHMEN USED A BOLT THRU SMALL END OF ROD??? U FIND THOSE, IN GOOD SHAPE, IN OIL PAN...
