carb back on
walko
ok got my carb back on thinks for the pics of the local of jets. runs good still need to adjust it agian. Took it out for a spin to a buddy house and on the way back ran out of gas. ? is how long should a tractor run on a gal or so of gas. I went about 8 miles and ran out. only had the fuel turn on a turn or so. fuel bowel/ shut off is new. along with the carb rebuit. just a ? not unhappy with the out come of the carb or how it runs also it a 47
[b:651fb1795f][i:651fb1795f]
Walko;
Happy to help ya out with the pic., and glad you got it done, with out goofin' up the jets. That can be a PITA, if ya goof up, and end up having to drill and tap. 8)
Gary :) [/i:651fb1795f][/b:651fb1795f]
walko........a 47 is a 3-speed 2N and hi-gear is about 8mph at full throttle. You should gitt about 1-gal per hr plowing in 2nd gear. Yer 10-gal gastank has an 1-gal reserve accessable by opening yer under-the-tank glass bowl valve to 4-turns 'stedda' the normal 2-turns. That shouldda gott'cha home. Remember, when driving on the hi-way, keep yer teeth closed so you don't swaller enny buggs. ......Dell, the bugg taster, patooie splat!!!
(quoted from post at 00:05:14 05/05/09) walko........a 47 is a 3-speed 2N and hi-gear is about 8mph at full throttle. You should gitt about 1-gal per hr plowing in 2nd gear. Yer 10-gal gastank has an 1-gal reserve accessable by opening yer under-the-tank glass bowl valve to 4-turns 'stedda' the normal 2-turns. That shouldda gott'cha home. Remember, when driving on the hi-way, keep yer teeth closed so you don't swaller enny buggs. ......Dell, the bugg taster, patooie splat!!!
Ate lotsa bugs on MC, but a grasshopper @ 90 & I thought I had been shot!
(quoted from post at 23:08:43 05/04/09)
b:f24c530b96][i:f24c530b96]
AH!!.......The old, "bug stains on the teeth Deal"....means a man is HAPPY with what he is drivin'. :lol: 8) :lol: [/i:f24c530b96][/b:f24c530b96]
