Dean Plute
I have a 1995 Ford 4000 4 cylinder gas engine. A few months ago had the carburetor, Marvel Schbler TSx-813 rebuilt. For a few months the reactor ran good. Went to start.it the other day an had a serious flooding problem (had gas coming up into the exhaust). Contacted the shop and they said pull the bottom off the card as the float needle may be clogged. Did that and noticed the float was dropping causing the needle to drop to far and was cocked between the needle seat and the top of the float flange. Tried to adjust the flange but same thing keeps happening. Doing some research I noticed that some needle floats have a retaining clip for the needle. But the one I have in the carburetor does not (see attached photo). Is it the wrong needle float or does the float itself need to be replaced? If it is the wrong needle float what is the correct one. The other numbers/letters on the carburetor ID plate are 64F.
