I'm not 100% sure if this is the correct number for that carb since there are 4 basic sizes of the M/S carbs. But if it is the small or medium the Walker brand kit would be the 778-505A. That kit covers the carbs like on the 8N and comes with 2 different side bowl gaskets. Or if you send me an e-mail with that carb info I'll call O'Reilly's and get you the correct carb kit number
Thank you old that is the no. I have from O'Reilly's But that is for the small to medium carb. My carb is big and most places that I have seen the kit it costs 50 to 60 dollars the main jet on this carb is in the bottom TSX 813 by the way a overhaul gasket kit does not have the carb. to manifold gasket thank again again
With the carb number you have O'Reilly's should be able to look the kit up for you but if your local place cannot do so let me know and I'll get you the correct number,. Kit will be in the $20-25 range form them
