Carb not carbing
Pete Ward
A guy got his father's 8n home. It has not run for 10 years. Put points ect. in , had carb re built at ford place.Now the only way it will run is with the choke out most of the way.
the gas lines & filters cleaned, carb bolts tighted new gaskets What do you think ?
needs choke to run:
could be fuel obstruction.. IE.. not good fuel flow from tank/ valve.. or internal to carb.. like sticky / obstructed flaot.. or misadjusted.. or cloged jets.
could be vacume leak.. vacume leaks leanthe mix.. choke enriches the mix.. thus if you have a vacume leak, adding choke masks it.
could lso be weak sparks.. poor orange sparks fire an enriched mix better.. that's why choke helps during starting.. rich mixes pop better..
spark is easy to tesk.. pluu a plug wire and use on a spare plug opened to 3/16 air gap.. look for blue/white snappy spark.. if you got it.. look at fuel next..
( propane torch unlit, canhelp find vacume leaks. turn on and wave around carb gaskets. listen for engine rpm changes ).
soundguy
Rebuilding the carb may not be the same as a good cleaning. I had my carb apart three times before I got it to run right with no choke. Make sure you've got good spark. When they rebuilt the carb did they soak it in cleaner then blow out the passages with compressed air? I thought I had mine "clean enough" the first couple of times, but clean enough ain't clean enough.
