carb problem on 464 int.
DB of Mi.
Will a bad fuel solenoid on a marvel carb cause tractor to only run with choke on full? I cleaned carb but it made no difference.
See if you have power to the solenoid, if you do remove solenoid from carb and ground it to the tractor and watch to see anything move in the end that screws into the carb and see if you feel it click every time you put power to it. Brent
