carb questions
I have 2 TSX 62 carbs Neither has Marvel Schebler embossed on the top edge both have the number 227 485 embossed where the marvel schebler usually is. Both have number 310015 under the tsx 62. Best I can figure is the 310015 is a ford number. I looking for a rebuild kit. What other tsx number would cross. All the kit I've found have found have a latter ford number of 312955. Also what's the differences between the 310015 and 312955 other than production date. Obvious both have been replaced as one is from a 58 961 and the other from a 64 4000 4 cyl.
According to Steiners Ford part number 310015 belongs to the TSX662 carb. I can't post a link because it's blocked on this forum. Try googling or going to Steiners.
Also there is a PDF on the web for Ford TSX carbs that confirms the info in my first post. It's a blocked on this site too so Google "ford tractor carburetors - tsx series.pdf" to find it. Then scroll down to Supplement 1 plus a couple more pages and TSX662 is listed with a Ford part number of 310015.
Yes, Andy is correct. Yours is an aftermarket type of carb, M/S TSX-662 would be used on Ford 801/901 Series models. P/N 312955 is the TSX-769 carb number, also used on 801/901 models. What are you working on/looking for?
Tim Daley(MI)
