Posted yesterday about "boogering up" my idle jet when I attempted my first carb rebuild. Been worried about how to get the idle jet out without damaging the carb body. I talked with a mechanic friend this evening for his suggestions and he said that since the "ears" (that allow you to remove it with a screwdriver) of the jet were all that appeared to be damaged I could probably just "clean" that side of the jet up so the brass doesn't crumble and leave the jet in. I hadn't thought about that but it does make sense. I was wondering what y'all's opinion would be on this. Rebuild it with the same idle jet in and see how it runs or try to replace the idle jet? Wish I had never tried to remove it but it is too late now. I also have another issue that I didn't address in my post yesterday. The big drain plug on my carb has been replaced (?) with a plug that is removed with a big screwdriver. I have not been able to get it out. Should I try to replace it or leave it alone. If it should be replace, I welcome suggestions on how to do it. Thanks!
