Bohinny
I posted yesterday about the tractor running better with main jet out of carb and 1/4" choke. I checked the carb agin and all pasages are clean and the carb is a m/s241B looks to be fairly new but not certin since i have only owned for several months. I did replace the ignition switch and that did not help. reset the float and still no better. is there anyway that the idile and econimizer jet got switched. or is the main jet to small. this is realy starting to frustrate me. I sprayed starting fluid around the intake and manifold with no change to engine speed. what size should the main jet be? the idile screw does very little when i adjust it. is there any other things that i am not thinking of?
(quoted from post at 20:44:30 04/13/11) I posted yesterday about the tractor running better with main jet out of carb and 1/4" choke. I checked the carb agin and all pasages are clean and the carb is a m/s241B looks to be fairly new but not certin since i have only owned for several months. I did replace the ignition switch and that did not help. reset the float and still no better. is there anyway that the idile and econimizer jet got switched. or is the main jet to small. this is realy starting to frustrate me. I sprayed starting fluid around the intake and manifold with no change to engine speed. what size should the main jet be? the idile screw does very little when i adjust it. is there any other things that i am not thinking of?
e4rminology is likely a bit of a problem here. By "running better with main jet out of carb and ", I am going to bet that you mean 'with the main power adjust needle' out of the carb, rather than that you have removed the main jet from under the nozzle. Is that correct? Next, the idle and economizer circuits can be totally kaput & tractor runs perfectly well at speed without both of them........but the main jet & nozzle need to be clear.
Of course if idle ckt is kaput it won't idle right.
So then how do you know the passage ways are clean??? I know you can not see inside of them so unless you have run a wire ALL the way in and out of them you can not say that. Yes I have worked on many many carbs and they can seem good and clean but all it takes is one single flake of dirt or rust and that will cause a problem. Yep BTDT many times and done well over 100 carbs and once in a while one can kick any body's butt. Takes time air socking and spray carb cleaner and then even a few more tries. Had one like yours that to fix it I set it in the house oven for a hour at 350 with all jets out of it
do these carbs have different jets for different altitudes. what is the best way to measure the main jet? is there a drill bit size that i could use to check the size. I had my father in law take it apart tonight to recheck pasage ways for me with wire, he said there was one that was questionable. I will try tomarrow. Thanks for all the replys. just trying to learn about something twice my age. fun most of the time but this is kicking my a$$
(quoted from post at 23:22:26 04/13/11) do these carbs have different jets for different altitudes. what is the best way to measure the main jet? is there a drill bit size that i could use to check the size. I had my father in law take it apart tonight to recheck pasage ways for me with wire, he said there was one that was questionable. I will try tomarrow. Thanks for all the replys. just trying to learn about something twice my age. fun most of the time but this is kicking my a$$
rill sizes from #55 to #60 will be fine. Your final tweak on mixture will be with Main power adjust needle & that & main jet are in series. i.e., with Main Power ADJ needle, you can completely shut off flow to MAIN Jet (and to all carb ckts for that matter, incl idle). To emphasize what/where Main Jet/Power Jet is, see pixs.
